Replace dormer window from inside only.
24 Aug 2011
Hampshire
I want to replace a first floor dormer double window approx width 1280mm x height 740mm.
One side is fixed the other opens. Both have four panes. Access from outside is difficult because of a sloping roof. I want to avoid ladders and scaffolding.
With the window out I can lean out and reach all around the outside of the frame.
Is it possible to install a window from the inside?
Yes it is, obviously the window has to be smaller than the interan dimensions of the opening.
Its a bit hairy holding the sash out of the frame in the open position whilst getting a screw top and bot in the friction stays.
A window fitter would prob do it, but for H and S reasons prob should not.
