We're having a small extension + kitchen/dining room wall taken out to make one open plan space.
The existing building (1938) has mostly vented timber flooring, though in the kitchen a small area is concrete (and I suspect under the cabinets is, too).
As ever, the flooring has competing desires :
- floor surface to be herringbone parquet-*style* (but using engineered blocks)
- FFL to be the same as the rest of the house
- to insulate from the cold
- wouldn't UFH be nice. (Wet, as IMHO it's the only system that makes any sense)
My initial plan was to take the existing floorboards out, skim 18mm off the tops, put a plywood subfloor on top then flooring on top of that (because of small blocks of the floor shape). Underneath use retro-fit wet UFH system (fill out with celotex, pipes through dry mix on top).
I lifted a few boards to have a look-see. The floor joists are about 98mm (so I guess a nominal 4"), then there's a ~230mm void, then concrete.
My feelings are that if I trim the joists, there's not a lot of room for insulation and something for thermal mass - plus it's a big ask for heat to go through the plywood *and* the engineered floor.
I've seen a different system that routes pipe through the subfloor and has 'heat plates', which is perhaps an option, but I wonder if it's going to work terribly well.
My secondary thought was - given the ground under the void is concrete rather than soil - and we'll need a new floor anyway for the extension pad - perhaps just continue on and make the entire area a 'modern' era construction (concrete, insulation, screed).
My query is about what would need to be done for damp-proofing around the edges, re-enforcement requirements, build-up (350mm is relatively deep, whether to put extra thick layer of concrete, more insulation, etc). The rooms surrounding it all have external walls, so will continue to be ventilated.
