Hello all.
I know this topic has endless threads but each one is different.
I am needing to change washer on downstairs hot tap. So I went to airing cupboard and turn the gate valve on the feed to the HW cylinder from the cold water tank in the attic. This is a Peglar valve and has a very short turn right to left. But the hot water does not stop flowing. Bizarre as no other pipes feed the cylinder.
18 months ago I had new WB system boiler fitted which is fully pumped and this replaced a CF Ideal standard gravity HW pumped CH. This was done by a competent engineer who left the HW system in place and just connected the boiler to the HW feed and return to the cylinder from the new boiler with diversionary valve/tank thermostat.
The Peglar valve has a very short turn right to left. I presume this is correct and not one you use to screw in tightly.
Any ideas? Thanks
Any ideas? Thanks
