Replace mains smoke alarm.
20 Jun 2010
Hertfordshire
Folks,
I've got what look like new smoke alarms in the house and one in the kitchen which looks ancient / rank. Obvious attached.
New - fine
Rank / kitchen
Could someone point me to a replacement for the kitchen please?
C
Both of those are ancient bases with slightly newer devices shoved on the top.
The kitchen one is well over 20 years old, the BRK may only be 5 or so years, but could easily be older. There should be a label on it with the date.
If they are linked together (as they should be), it's replace all of them.
I don't know - I assumed as they are mains (installed c.1999).
Should the test function trigger all?
Replace both Aico units and you can do away with the surface back plates ….
Sorry, don't follow.
I've just tested them and the newer ones work on the test function - and trigger the others - but the manky kitchen one does not work!
This means I *must* replace at least this one.
Your life to risk …..they have a 10 year replace date for a reason ….if you think your life or your family’s is not worth £40-50 then leave it ….
I'm assuming you have dectectors in upstairs landing/downstairs hall and kitchen?
All existing dectectors look past their best, as someone else said you'd be best swapping all out for Aico, you want A heat in the kitchen, an optical in the downstairs hallway, and generally most recommend an opitical for the landing, although if its close to the bathroom and steam could be an issue then you may consider an ionisation type instead.
The budget option (with 9v backup battery that needs changing every few years) is the EI140RC series. Ei146 for optical, Ei144 heat, Ei141 for ionisation, they come with the correct bases.
The other option is the 3000 series that has a 10 year backup battery thats good for the life of the device. Ei3016 optical, Ei3014 heat, thers also the Ei3024 multisensor
In rented properties you need to go for the 10year battery backup option, but if owner occupied then you are free to choose the 9v battery option if you wish
Thanks all. Very good help and advice. I'll pick them out and confirm tomorrow.
I assume swapping them is easy for a competent DIY person?
