Replace missing radiator - help please
4 Apr 2011
Norwich
yes it will work you can buy adjustable rad valve tails or tail extensions
the link that you have put should do the job
Yes it will work, but you may need extensions both ends. If you intend to keep your existing valves then check they are both 1/2" connections to your extensions :)
The length of a radiator is usually equal to the distance beween the horizontal tappings the valve union tails screw into, not the distance between the valves. Once the tails are fitted to a 700mm rad. they will probably work out at about 740 - 750mm apart without any adjustment.
