Hi Guys,
I'd appreciate a liitle help on replacing a 2 gang switch(plastic) with a 2 gang touch/remote dimmer switch(Chrome). The problem I have is that the connections in the old light don't match the new one. Here is the old switch config:
There is currently a 2 Gang switch with operates 2 separate ceiling lights individually. There is single 4 core cable going to the switch, consisting of red, yellow, blue and earth (with green/yellow sleeving) cables.
The current switch has L1 L2 and common terminals at the top and then at the bottom has common L1 and L2 terminals.
The red cable goes to L2 at the top (there is also a separate red loop cable going from L2 to Common at the top). The yellow cable goes to the Common terminal at the bottom and finally the Blue cable goes to L2 terminal at the bottom. The earth cable is not connected and is sheathed presumably as it was not required for the plastic switch.
The new light fitting is metal and and has 2 boxes at the back for each gang. Each gang has 3 terminals marked Live, S-Link and Load. My dilema is how do I connect this new dimmer switch to my old switch wiring.
Any help would be greatly appreciated. I am happy to post any pics if required. Thanking you all in advance
