hi guys and dolls, the prd on my gainsborough shower has gone. is replacement a diy job, i instaled the shower 2 monthe ago. i think the prd cut in because the shower head was scaled up (now cleaned). any advice very welcome. geoff
Prd on some of latest Gainsborough`s is just a ball off silicone type stuff in a housing on the outlet pipe . This housing is usually quite tight to the wall so ball moves to let water out but doesn`t fall out of housing.. 2 screws remove outlet pipe from unit and ball may still be in there and can be pushed back into place. As say this is some Gainsboroughs
