Replace Roca fill and flush valve
7 Aug 2008
Farndon
Hi all,
I'm looking to replace the flush and fill valves in my Roca close coupled toilet. The Roca ones have both broken in some way and I've already repaired them in the past (horribly tacky!)
Will I be OK using the Fluidmaster products from Screwfix? The only difference I can see is that the flush valve uses a cable.
If so, is there anything I should watch out for?
Cheers
Yes, pretty straightforward, sometimes the most difficult bit is separating the cistern from the pan (replace the doughnut washer between the two when you put it all back together).
