My fan oven element died a few days ago, tripping the mains RCD. Having replaced it a few years ago, I knew what to order and how to do it, so I installed a new one. Everything seemed to go smoothly, but one of the spade terminals on the old element was blackened and worn away, it looked like what happens when a terminal is sparking. The spade connector on the wire was loose on the new element so I cleaned it and pinched it tight. It now fits tightly and the element installed normally. However, within 30s of turning the oven on to test, the mains tripped again. This seems to be to do with the element starting to get hot - I waited half an hour and the same thing happened - a little delay, then tripped mains.
This suggests to me that the element is shorting to earth, a dangerous situation that I wish to avoid. The element has no earth terminal, so I think it must be shorting to the casing via the mounting screws. I've ordered a second replacement to see if it's just a faulty element, but is there anything else I should be checking?
