Last week I removed my central heating pump to clean it out. The pump isolating valves were old and corroded and wouldn't shut, so I had to drain down, and then took the opportunity to put new isolating valves in.
They looked identical but when I came to refit the pump I noticed the valves were slightly more compact, so now there is a small gap and I can't refit the pump.
The thing is, tomorrow I am getting a powerflush done. I've read that the first thing he will do is remove the pump - so should I just leave the pump disconnected from the pipes and not worry about it?
I'm getting a new pump (the plumber convinced me it was worth it) so the gap will need adjusting then anyway.
