replaceing a florescent light fitting
31 Jan 2004
I have had to replace a florescent light fitting in my kitchen, I have 3 red wires, 3 black wires and 3 earth wires. The wiring seems to be completely different to the fitting that was there before.I have the 3 red wires together in a connector and then 2 of the black wires together in a connector with the other black wire in a separate connector. On the body of the fitting there are the connectors for the LIVE, Neutral and Earth, but there is a link in (factory fitted) connecting the Live and the Neutral. I have had the fitting working but somehow it has bypass the On switch. Can anyone help with how I can wire the fitting so it goes via the On switch please,and also should I take out the link in.
Thanks Colboy
it would seem you have wired it wrong.
leave the 3 reds in their connector block, the two blacks go to the neutral , the one single black should go to the live
and the earths to the earth terminal
Factory fitted link across L & N?????
Is this a capacitor?
ishould suspect it is, otherwise we would have heard the bang
