Replaceing an felt roof with an tiles roof
9 Jan 2010
Leicester
Hello all,Could do with some info,
My front porch roof at mo is an flat felt roof but its due for an refelt soon,my brother as some spare tiles which would cover the area i have.
The roof is 4m wide and from back to front is 750mm what i need to know is what wood to use as my frame.also its 750mm deep so how high would i have to put my banton on the wall for the top of the pitch..
Thanks Rick
you might be in trouble with the local planning office of the council :eek: .there is a height limit to porch roof . Best check with them and see if you can get a pitch on there :idea: . It`s all too easy for nosey neighbours to see , is a front porch ;)
Thanks for the reply.There are afew round here with the same ideas,in fact there are some with even bigger pitch roofs than mine would be.I guess the council should be an go on this,aswell to have same sort of tiles to match the main roof,,but i will check it out,also would makein the frame out of 3x2 wood be ok etc for rafters etc..Thanks Rick
