Hi Guys,
The inevitable has happened and after around 22 years my Ideal WLx RS60 boiler needs replacing.
Yesterday i was all for a new combi, but the more i have read and thought about it, i have decided to go for a condensing boiler and keep the hot water cylinder etc.Cannot be doing without heat and water with a combi if it goes wrong.
Our present boiler is in the garage and has caused us absolutely no problems in all these years, and even as knackered as it is (and leaking water slightly) with a bucket underneath!, the ole faithful is still working.
So, my question is, what would the equivalent boiler to this be in terms or reliability and size 60btu, and also the cost to replace? Are Ideal boilers as good now as my old one? Should i consider something different?
I have a hot water cylinder in the airing cupboard (bungalow) and a 3 port valve and a grundfoss (is that how u spell it!) pump just above near the cylinder, i think that is for the hot water. SHould these all be replaced as well, apart from the 3 way port all the other parts i think are original.
Also the control panel for the boiler and water is in the airing cupboard.
Sorry for the long post, but really need some advice in picking a reliable replacement.
many Thanks
Lorraine.
many Thanks
Lorraine.
