Hello all,
our old boiler sounds as if it is on its last legs.
We have the British Gas covercare but it is on their limited parts list.
Just had the addition of twins to the family so obviously a breakdown would be pretty disasterous at the moment.
Had a quick quote from a local plumber of £1500 to replace the conventional boiler with a combi (unsure if it is condensing) and fit TVRs to all (10) radiators.
I have two quick questions regarding the upgrade which are bothering me:
1) We have solid wood flooring downstairs and a tiled reception room and en-suite. Can the installation, other than the removal of the water cylinder, be done using the existing pipework?
2)At the moment, the shower in the en-suite is fed from a pump. Will this work with the combi or will it have to be removed? I have read that there can be pressure drop whilst using a combi fed shower and other appliance.
Thanks,
Ed
Thanks,
Ed
