I have a 26 year old external oil boiler I need to replace. It is a standard heat only setup. If I change to a condensing boiler would there be any more pipework. The current pipes are buried underground from the boiler to the house. Thanks.
I think it'll be grant. Not as much choice in Northern Ireland. I also looked at warmflow, but they don't seem to get great reviews. Also would you recommend non condensing over condensing? Is there much difference in efficiency? Thanks.
Hounsfield and EOGB will both ship to NI I think. You should get about 10% better efficiency with condensing, and more with the EOGB Sapphire as it's modulating rather than fixed output
