Replacement cover for drain inspection chamber
23 Jan 2022
There is a terracotta surface water drain inspection chamber in my garden where the existing cover frame is corroding, and given I currently have that area of the garden dug up, I want to put a replacement frame and cover on the chamber. This will have been installed in the early 1980s when the estate was built.
Currently, the frame rests on top of the inspection chamber riser, and can be lifted off.
Working out what size cover and frame I need to buy is proving challenging. There are numerous sizes available but it's often unclear which measurement is being referred to in the product specifications.
I've attached a couple of images showing the inspection chamber, and existing cover and frame, annotated with the measurements.
Any pointers on what size (or even specific products I should look at) would be much appreciated.
Many thanks
