Replacement doors - in a Georgian flat
25 May 2013
Liverpool
Hello,
I have to replace all of my doors in my flat: 3 external doors (external to flat, but opens to common area) and another 4 internal doors. All of the previous doors did not pass fire safety, and none where original sadly. They were all rather cheap, actually.
Anyway, I came across Todd Doors, but are there any other sources? They seem expensive. My builder says that my doors are unique in dimension, not fitting a standard size (georgian). He has already been rebuilding the door frames, and says the new doors will have to be adjusted/cut on site.
So: Any suggestions for other door companies?
And: Todd Doors (when I spoke with them) said that they can match a rebated panel details which surround the door frame, into the 6 panel door. But, rather pricey. Any one else?
Any feedback? Thanks
are you going to tell us what size these doors are, and what is "pricey?"
Are they 4-panel or 6 panel?
Will you be painting them?
Fire doors usually have a deeper rebate and use a special lining (doorframe)
