Hi
In our 1935 house, I have two outside lights, one of which stopped working. When I tried to change the bulb, I found the fitting was broken.
A replacement bulkhead light requires an earth, but both of the existing fittings have only live and neutral (black and red), with no earth and none visible (or cut short).
The double light switch is immediately inside the front door, with one for the two exterior lights and one for the inside hall light.
There is an earth wire within the light switch, but (inside the adjacent small access hatch in the thick granite wall) there are only two cables, sheathed in black rubber, running up towards the top of the door and then presumably outside (and none running elsewhere).
Is the only solution to replace the existing cabling with twin and earth?
Thanks in advance for any help!
