Hi Folks,
I have a Baxi Duo Tec combi with a rigid filling loop. I have had to remove the non-return valve from the filling loop as it had failed (a common fault apparently). I'd like to replace the loop but the correct part is around £50 and a universal fitting is a tenner. Is there any reason (other than looks) for using the original part? Would something like this one from Screwfix just do the same job?
http://www.screwfix.com/p/r24-filling-loop/83905
Cheers,
Mark
Cheers,
Mark
