I've just found this great forum and this is my first post but i'm sure it won't be my last.
I've got a British Gas branded (Grundfos made) Multi Head G Central heating pump Part number 56506180 that has given up the ghost. I've tried removing the central screw, inserting a screwdriver and turning but it won't budge, so I need a new pump.
As it would appear that this pump is no longer made can someone suggest a direct replacement that will just bolt on?
the full spec as written on pump is as follows:
P/N: 56506180
230V 50Hz
PC:0819
IP:44
TF:110
Class:F
Many thanks for your help.
P/N: 56506180
230V 50Hz
PC:0819
IP:44
TF:110
Class:F
