Replacement for Danfoss HSA3 Three port valve
5 Feb 2007
Cambridgeshire
I'm going to replace the three way valve as I know mine has a slight leak and isn't really working properly anyway (over hot water when CH is on) - I think the valve itself is partially broken. It has certainly jammed up at least once requiring 'help' from a grip to get it moving again.
Perhaps someone can answer the following Q re: this. After reading the forums the Danfoss HSA3 seems to be prone to leaks. I would like to replace with something more reliable, but without having to change wiring/pipework.
Are there any direct replacements that fit the bill? (i.e., no pipe work or wiring changes)
The Honeywell V4073A 3 Port Motorised Valve seems to fit the bill, and Honeywell has a good rep. One Q about these though. The last house had one but you could not change the head on it without draining the system, unlike the Danfoss above. However, I believe this was an old design and modern ones can have a head change without draining. Is that correct?
TIA
James
Honeywell V4073A have changeable heads now + it will have a earth wire as you present one don't
for diy reasons just fit same for same.use existing nuts.
fully drain out your system and refill with inhibitor added.
i had a drayton valve exchanged years ago with a honeywell all ok but an annoying knocking noise through pipes when valve moving between ports at certain times.
installer said it was normal for the valve to slam shut at times.
sold that house,some one elses problem now.
Thanks all,
sounds like the Danfoss will be OK then. Only a couple of quid cheaper, but the head still works, so could just replace the valve part (can you buy them separately?), and leave myself with a spare head unit.
Thanks again.
James
Ahh. Think I was right above - the HSA3 is the head unit (correct term - actuator?), HS3 is the entire unit.
Had a look at prices just for the valve, nearly as much as the whole unit. (55+ compared with 69), so will go for whole unit giving me a spare actuator unit I reckon.
Thanks again all.
James
