There are 3 Wickes R63 eyeball downlights in my kitchen. The other night, one of the holding clasps (if that's what they're called) broke and the housing fell out of the ceiling.
I need to replace this, but can't find anything of the right diameter in the DIY stores I've looked it. The hole diameter is about 140mm/5.5". The diameter of the covering/fascia ring (i.e. the thing you see around the eyeball when you look up) is about 150mm/6", and it's white.
Does anyone have any suggestions as to where I can find a replacement? Wickes don't stock them any longer, since virtually everything is halogen now.
Thanks in advance.
Thanks in advance.
