I have a 2 bedroom flat which has electric heating/electic hot water which is on economy 7. The hot water tank is 6ft high with a two elements heating it (night and day) and appears to have a smaller header coldwater tank built at the top of the tank which coldwater tops up the tank via a ball valve. I have replaced the heating elements a few times over the last 10 years. The tank is starting to drip where the bottom element screws in and last time the elements were changed is full of calcium at the bottom of the tank so I intend to replace the tank.
Could I fit a direct tank unvented? or do I need to fit another direct vented tank? What are my options? I have tested the water pressure on the incoming mains and it is 2.5 bar. Any advice would be appreciated. Thanks
