We've got an Ariston 15L 2kW under-sink water heater. A couple of years ago it started tripping the RCD, and was found to be leaking around the element gasket. Nice dripping wet electrics! I got help from a plumber and we replaced the element, gasket and anode.
I't now started leaking again but *not* from this same area - the gasket and all the wiring and so forth are dry. It's oozing not gushing, so I can't imagine where from really. If the tank had rusted through I'd expect more outflow.
I'm wondering whether to cut my losses and buy a new one. Could I have opinions on please:
- Does this sound repairable? Known issue?
- Are Ariston an OK make? I think this one lasted 7 years, including the above repair at age 5 years. Is this typical or should I have expected better?
- What other makes to consider? (We have a Zip at work and it seems good)
- For efficiency should I consider an instant water heater rather than another immersion type?
