We are currently in the process of replacing the interior doors in our house, and have opted for some cottage style Oak Veneer ones like these:
http://www.diy.com/departments/cottage-panelled-oak-veneer-internal-door-h2040-w826mm/176345_BQ.prd
These are fine for most doors in the house. However, our lounge has French doors on it, which seem to be an odd size (approx 67cm wide each). I'm struggling to find any doors anywhere which match this size. Obviously a solid door can be trimmed - but none of the ones I've found match the style.
The nearest in the range we have is this:
http://www.diy.com/rooms/10-lite-oak-veneer-internal-door-h1981-w686mm/175187_BQ.prd
But being veneer, is there any way to trim this to the correct width? By taking part of the veneer off, and putting it back on maybe?
And also, being a French door, there is usually an L section cut at each end where the join which helps secure the door - but are these always required for a French doors? Being veneer, these can't be cut in for obvious reasons. But can French doors work without them?
Steve
Steve
