Hope someone can help me with this please:
Wearing my electrician's hat, earlier on today I went to replace an immersion heater element that had burnt out. The cylinder was already drained when I got there and the element is an 11inch type that fits sideways into the bottom of the cylinder. The cylinder is also mounted fairly high up on a shelf so that the top is nearly touching the ceiling, and the gap between the top and the ceiling was filled by a scrunched up lagging jacket.
All that was fine (element fitted and tested) until I turned the water back on, when the cylinder started leaking from the top. Further investigation revealed that this "cylinder" has a flat lid covering the top of it which was slightly warped and corroded above where the cold water comes in (the arrangement is like that of a cistern with a ballcock, etc. only the water shoots right up and at full pressure was almost pushing the lid off).
What I need to know now is whether anyone knows if lids like this are still made (the tank is supposedly only 10 years old) and where I might be able to get one from. It might also help if someone could tell me what sort of cylinder this might be as I've tried searching on a few plumbing sites with no luck.
I appreciate that the conclusion most people would reach about this episode is "buy a new cylinder" but the person in question is a pensioner and they can't afford to have a new one fitted.
Any advice would be much appreciated
Many Thanks,
Neil
Many Thanks,
Neil
