- Joined
- 5 Dec 2020
- Messages
- 2
- Reaction score
- 0
- Country
Hi All,
I’ve had a Siemens CMV 322 3 port 22mm valve on my heating system for around 4 years, but the valve has ceased. The actuator itself appears to work ok but I can only get the boiler to switch on for hot water and not the central heating.
I’ve tried to search for just the 3 way port but it appears you can only buy both together?
If I could just get the valve I’d buy it but I’m a bit reluctant to buy the whole unit again as it’s not lasted too long.
Has anyone seen the valves only for sale or can anyone recommend a replacement that would fit and work the same (Honeywell perhaps?)
I won’t fit it myself, but I don’t want an expensive swap.
cheers
Ross
cheers
Ross
