Replacement pop up plug for old (50's?) unibloc
11 Aug 2008
Cambridgeshire
I have a very good quality bidet probably a 20+ years old. Problem is the mono bloc has lost it's pop up plug. I could replace in total with a new bloc but the taps are just so nice. Any thoughts on where I can get hold of a pop up plug?
Also the tap tails are not like modern tap tails. they are about 15cm long by 10mm and are an actual part of the tap, not screwed in. I think my only option is the cut off the old olives and refit to a 10/15 adaptor then to a 15mm flexi fitting.
Dosh
