Afternoon all, I have an existing porch located on the front elevation of my house, it's approximately 900mm deep and about 2700mm wide, door is located on the right face, window on front elevation approx 1500 wide, smaller window on left elevation approx 850 wide, base is concrete and appears in good condition, roof is flat and is an extension of the garage roof.
The porch is timber construction and is in quite a poor state, with the base and roof being sound I would like to replace with a new timber frame, a UPVC door/frame in place of existing timber door, new UPVC window in place of existing sheet of glass, the timber frame would then be insulated, plasterboard and skimmed internally, externally would have a suitable ply or other material applied (open to suggestions) then looking at installing brick slips, so would appear to be off brick construction.
To finally get to the point! Would there be any building regulation issues? Tried to speak to my local authority who quite frankly were as much use as the existing porch!
I do not want to really go down the route of brick built as this would require either a reduction in internal space, or larger overall footprint, which I believe could require planning, also cost wise I have received a quote which was quite frankly astonishing!!
