I am thinking of replacing my existing central heating pump with a Wilo Smart pump
The existing pump was fitted to the system in 1984 and rotates in an anti-clockwise direction. It is in a pipe that feeds into a junction where motorised valves for hot water, ground floor heating and first floor heating combine
The Wilo smart pump rotates in a clockwise direction.
I think this means that if I drop the Wilo pump into the system as is, it will push/pull the water in the opposite direction to the direction the current pump pushes / pulls the water
So the questions are;
1) are my assumptions correct ?
2) if the water is pushed/pulled in the opposite direction does that matter ?
3) is there likely to be any configuration on the pump to change the rotation direction ?
4) if there is no rotation configuration, and the water still needs to 'go the same way', can I get round it by fitting the Wilo pump back to front and upside down ?
Thanks for any advice
Geoff
Geoff
