Hi Guys, im hoping I can get some advice...
I have moved into a new house and the radiator that heats the main room is old and not giving out much heat. I think its full of shi* and I know I can get it flushed but due to its age, I thought a new more efficient rad with fins etc may kick out more heat and be cheaper to run.
The current rad is a double 700mm high and 2000mm width. I did one onf those BTU caluclations and it said I need approx 7900 to heat the room.
For ease and to save cost, I was thinking of getting the same size rad but a single with convector fins etc so it can be easily replaced and will give out the heat required but as its a single, should be cheaper to heat?
IS this a good idea or is it best to get a smaller double one and have pipework extended by a plumber?
Finally, can you reccomend any radiator ranges? I have spent hours looking and the price varies so much and I cant see why! I just want a cheap efficient one!
Thanks in advance.
Thanks in advance.
