I’m trying to track down some replacement TRV heads for my heating system.
This is a fairly old system – over about 15 years of age for sure and the TRV’s are a fairly simple design from my assessment – they appear to use a sprung metal top buffer coupled to a moving double spring-loaded plunger which manually effects the spigot that controls the flow in the valve body. Unfortunately one of my valves has rusted away and the result is that the radiator is on full all the time – producing a silly amount of heat which is proving to be a hazard to my children. I have rectified as best I can with some thin metal sheet (from a small candle) and roughly cleaned up what was left of the springs (almost completely corroded away) the trouble with having a radiator in a bathroom I suppose.
All I really require is the replacement top body section as they simply clip onto the main Valve body by the use of a clip compression section which is then held in place by a metal sprung ring. As you can imagine I don’t really want to drain down my entire system to just replace this one valve with a new one and If I were to do that I may as well replace ALL of the valves on all Seven radiators.
I really hope that someone can help me track down these head assemblies that can simply be clipped right back on replacing all the current worn ones. I understand that most of them have SERVO Warm written on them – but one of these valves in one room clearly has MYSON stamped on it – so I’m assuming it was a MYSON rebadged valve that the company used that installed the heating.
Please get back to me if you can help out
Here are photos of the valve for your reference:
[/i]
[/i]
