Replacement required for Sunvic valve body EML 3454 22mm 2 port.
10 Apr 2016
As subject waning a body only to replace a Sunvic by another make that will accept Sunvic Actuator SZ2201.
Have read Danfoss do and might be HPV22 but seems the one they have is HPV22B, can I have confirmation if either or both will be ok?
Thanks.
Any reason you don't just replace it with another SZ2201? Either that or it may just be easier replacing the whole thing to make sure it can easily be replaced in the future.
Seems a lot of money to buy a complete SZV 2212 in order to get an EML 3454 for two reasons the Actuator SZ 2301 is working and I have a spare one too.
Yup ... fair point, though £45 isn't that much for a new valve body, especially a Sunvic, which always seem to be overly expensive -
Yes they are very much more than others and less available, hence this post for other makes/models that will take an excising Sunvic Actuator.
You probably won't be able to get an opinion as it's not a configuration that many, if any, would implement. The whole valve would be replaced, or if there were spare heads then another valve body would probably be fitted.
I presume the current valve body is leaking or similar and has to be replaced?
Oh yes agree. A professional would replace all, for ease as no matching any brand would do and more revenue.
