Replacement Roofing Material for a Lean-to Extension
14 Oct 2006
Moray
Hi Guys,
I have a 100 yr old house with a small extension (downstairs loo) built many years ago. The existing roof above the loo is corrugated metal and is now rusting and leaking onto the ceiling. Its time to change both the roof and the ceiling. The roof pitch is approx 15 degrees leading down to a gutter. The ceiling will be replaced with plasterboard and some rockwool sandwiched below the roof.
What would be your recommended replacement roofing material?
Many thanks
Kev
Many thanks, Masona. I shall probably be getting a couple of those insulated tile effect panels.
