Hope I can trouble you guys for a bit advice. We have a large rectangular tank in our loft that supplies our hot water(gravity) and tops up the pumped central heating. This has sprung a leak and needs replacing but after ringing round for prices I feel that there must be a cheaper option. I propose to replace it with an indirect combination tank and a seperate tank for the heating system top up. Questions1) I take it that feed and expansion for the heating system are accomodated within our existing tank. Is it sufficient to just 'tee' these connections into the visible 28mm pipes once connected to new cylinder.(2) What is the minimum storage capacity required for the new feed and expansion tank?
This is all I can think of at the moment. Hope you don't mind if I come back with some more questions. Thanks.
