Replacement Valve Washer/Seal - Gerberit?
2 Apr 2011
Hi I'm looking to fix a leaking toilet valve by replacing the seal/washer, hopefully that will fix the slow leaks. Do you think this Gerberit replacement washer would fit mine?
http://www.ebay.co.uk/itm/GEBERIT-8...SH-CISTERN-VALVE-DIAPHRAGM-SEAL-/221124603818
My leaking valve/washer, not sure if it's standard fit:
It's possible that the leak is not coming from the washer in which case I might have to replace the whole valve....
Thanks for your advice!
Personally I would replace the whole valve and the fill valve too whilst you are at it because that will probably stop working soon
