I want to replace a window cill in a curved bay window as part of remedial work I'm doing to deal with blown plaster and improving the u-value of the bay wall which is solid brick.
See thread in Building forum
My plan is to sand & cement render the wall and then affix insulated plasterboard which is then skimmed.
There will be a lip with the original cill as the finish wall will come out further than previous.
The original cill looks to have been bedded directly onto mortar (with no dpc) which likely explains the cracks in the top surface, possibly from moisture contacting the wood.
My plan is to replace the cill and place a roll of dpc beneath the replacement and have the new cill be deep enough to overhang the new wall finish.
Things I want to know:
1 - Suitable material for the replacement cill. Softwood or MDF? Are there other materials I should consider?
2 - What sort of thickness should I be using, 18mm?
3 - Best way to secure the new cill: A bed of mortar with dpc? Mechanical fixings? A combination? Gripfill?
4 - I'd like a bullnose finish but don't currently own a router. Can anyone recommend a router to purchase for such a task?
Many thanks
Many thanks
