We are getting some replacement sash windows made in wood with double-glazing.
Due to space limitation within the sash, the gap between the panes will be much less than most double glazing - something like 6-8mm.
This made me think warm-edge spacers might be worth using.
The only place we get condensation on the (uPVC) double glazing elsewhere in the house is round the edges of the panes.
But the sash window company are trying to dissuade me - apparently the glazers will only use aluminium for the vertical centre-bars that split each of the sashes in two.
So if I did have warm-edge spacers they would only be along three out of four edges in each of the four pane-sections, and they would not match in colour the aluminium down the centre.
The narrow cavity also made me think of asking for krypton or xenon instead of argon, which apparently performs very poorly as an insulator in narrow cavities. The firm has yet to give me an answer on this.
Am I tinkering at the margins here with things that will make hardly any difference given that we are moving from single-glazing to double?
Or should I stand my ground and have them done as optimally as possible?
