hi, I'm in the process of replacing a recessed 12V downlight (more precisely: one of two downlights operated by the same switch) with a 240V pendant. got as far as wiring things up again but the pendant doesn't work (the second downlight works though). I assume that's to do with the transformer, right? Any suggestions where that is most likely to be located? In the ceiling void?
It's in a 2 year old new built flat. I guess I should try to find the transformer, disconnect it from the supply and connect the supply directly to the pendant, shouldn't I?
In fact there are three sets of downlights, each on its own circuit/switch.
Any suggestions would be more than welcome!
thanks, t
thanks, t
