Replacing 17mm groove drawer runners
4 Nov 2011
Birmingham
Hello
I have a wardrobe that has 4 drawers that use 17mm groove drawer runners. Over the last few years I have had to replace the runners on numerous occasions.
I was wondering if there was a better solution, because all the runners that fit all seem to be rather light-weight.
Thanks,
Carl
Hi.
The drawers have grooves on each side that are 17mm wide that the runners fit into. They look like these: http://www.eurofitdirect.co.uk/17mm-mini-slide-ikea-drawer-runner
Unfortunately, all the ones I can find online are rated for 10kg, which just don't seem to be sturdy enough.
I did wonder if bottom-mounted drawer runners might be better, but I don't think they will fit (i.e. the drawer + drawer runners will be too wide).
Thanks,
Carl
Hi.
Unfortunately, I think those are pretty much the same, as the rating, per runner, is only 10kg.
Regards,
Carl
Apologies - misread the 20kg and, as you say, it amounts to the same 10kg per runner.
Must say I'm not so sure that a higher kg rating exists for such a thin (17mm) width. I think most (if not all) of the higher kg rating runners are wider than that.
Best of luck and apologies again.
B
under mounted wont work as the rollers and runners are between the drawer and cabinet side
do you have a space under the drawer you can utilise ??
my thoughts are 2x1" planed[20x44mm] batons screwed and glued to the cabinet sides under the drawer from the front to at least 75% off the drawer length
