Travis Perkins can normally machine most profiles if you have a sample. I've used them a couple of times, not the cheapest I'm sure, but they did a good job-the profile match was spot on.
dependant on profile it can be made from two pieces glued together then the extra cut off
either lower profile skirting or achatrave with plained timber added
old skirting was often made in more than one piece anyway
