I'm about to replace a 2 gang dimmer with a 2 gang normal switch as a bulb blew our fuse wire in the CU (i aso want to mak euse of energy saver bulbs).
The wiring seem to be a bit odd, i have 1 red (live) cable going into common of the first dimmer housing and the other 2 cables going into L1 and L1 respectively of the each of the 2 dimmer housing. However where the live cable goes into common, i also have a bit of the red cable coming out of the common from the first dimmer and into the second common hole of the second dimmer housing??
Should there be 2 live supply cables rather than one??
