replacing 3 way valve
28 Sep 2008
Devon
Hello,
I believe the 3 way valve of my heating system is broken, the old valve is model Landis & Gyr MAV-322, is this able to be replaced with model Honeywell VC4613-30.
If so can someone tell me the correct wiring as I am unable to find a diagram. :rolleyes:
I would appreciate any advice you can offer.
Many thanks
Julie
Initially boiler working fine, central heating stopped working but restarted when we opened 3 way valve manually by lever on side, now boiler will not even ignite ? needed new 3 way valve?
changing the synchron motor might sort it (and its alot easier) but ya could do with doing some tests first.. have ya got a multimeter?
Nothing, the boiler wont fire up at all, the switch on the 3 way valve moved when we tried to fire it up but nothing else.
fireyfaerie";p="1013938 said:
Nothing, the boiler wont fire up at all, the switch on the 3 way valve moved when we tried to fire it up but nothing else.[/quote
Well it ant yea 3 way valve then take a nice lie down and lets start from the beginning
What type of multimeter do I need?
Just discovered I need 3 way valve V4073A1039 not the one I had bought.
Julie :p
