I need to replace some 35+ year old radiators, sizes below, and I’d like to pick your collective brains.
Length Height Pipes c to c
1440(Double) 700 1520
800(Double) 700 870
640 540 720
965 700 1045
640 700 720
960 700 1050
960 700 1050
800 700 890
I’ve been looking at Kudox Premium radiators and assume that if I replace the doubles with double + single convector and singles with single + convector, I could probably get away with 600mm high radiators. Thoughts?
Next question is mounting. The walls are stud and plasterboard and I’m doubtful if I’ll be able to hit studs for most of the radiators. Is plating the wall with a sheet of MDF or ply the best solution and what anchors would you recommend?
The pipework is 8mm so I don’t seem to have much choice for TRVs. Danfoss RAS –C2 ok?
I also need to replace two Honeywell V4043H zone valves. Drayton ZA%/679-2 is much cheaper. Any difference in quality? The removable head on the Drayton sounds like an installation plus.
800(Double) 700 870
640 540 720
965 700 1045
640 700 720
960 700 1050
960 700 1050
800 700 890
