Hello all,
We have 4 TV's connected via 4 Way Masthead AMP V20-1420, there is a feed in from the aerial and 4 out connectors. This works fine but I wanted to add another TV cable. The TV's wont always be on at same time in case this affects the signal.
We also have a VisionV230-2102G power unit that seems to help this unit to work. It was installed by a TV aerial engineer.
I wanted to just replace the 4 way with a 5 way if possible. Is this an easy job? Are there any recommended units, I will run the coax in the roof myself for the extra TV.
Thank You
Thank You
