I've just bought a new house. I think the phrase you'd use to describe the state of it is 'ungg'.
One of the many, many misfeatures I've found is that the cold water tank in the loft (which feeds the hot water tank and bathroom taps) is uncovered. What's more, it's been uncovered for a while, including when the previous owner decided to replace all the tiles. I believe the technical phrase to describe it is 'full of crap'.
What's more, I'm in a hard water area. A lot of the crap is inextricably embedded in the limescale. I think it's basically a write-off.
My question: do I actually need a cold water tank these days? I know that the purpose of the tank is to lower the mains pressure and to isolate the mains from the low-pressure system, to avoid the possibility of contaminated water getting sucked back into the mains. Couldn't the same effect be achieved with the appropriate pressure reduction valve fitted to the mains feed?
This would not only save me loads of space --- the cold water tank is vast, about a metre on a side --- but would simplify the plumbing no end and reduce the amount of crap in the water.
If this can't be done, and I actually need a genuine, physical tank, then what are the guidelines for how big it needs to be? The tank feeds the hot water tank, cold taps on the bath and basin, plus the loo.
[Hmm. Looking at my preview, I notice that my post has been 'edited'. Let's just say that I used a slightly more forceful word than 'rubbish'...]
