I've got this radiator. It's really old, and slightly rusty, but is (as far as I know) sound.
I want to fit a thermostatic valve to it. I've got the valve (four pounds from Screwfix...), I've drained the system, uncoupled the radiator, etc.
The problem is that the radiator was hooked up using compression joints, that are now looking pretty ratty. The valve has nice, shiny new ones. Unfortunately I don't know how to get the old ones off; the olive has been bonded quite impressively onto the pipe. I can't simply cut the pipe, because it's not long enough.
What's the best way of doing this? Can it actually be done in a way that leaves the end of the pipe in a decent state? Do I actually need to --- can I just screw the valve straight onto the old compression joint and (with the help of PTFE tape) count on it making a good connection?
