We have a 60A wylex CU with meter tails being T&E (16mm probably) length 7m out of our flat through a utility room and into a common meter room, all circuits on 60a fuses and isolators. I am (subject to my LBA approval upgrading the CU as part of a part-rewire to a Hager 17th ed, which is 100A rated. In the future we may try and get our supply upgraded to 100A, but I am not going to do that now. However, while stuff is ripped apart I want to take the opportunity to upgrade the meter tails so they can be take 100A in future. But I don't want to draw all the way back to the meter room right now, only to part of the way to the utility room (a whole lot of different flats meter tails feed through the utility room as well). Is it okay to terminate the current 60A t&e in a junction box in the utility room, and connect it to 100A rated wiring (I think double insulated 25mms should be fine) through to my CU? So in future, a supply upgrade to 100A is easier on the wiring bit?
