Hi all,
On the basis that the only stupid question is the one that is not asked .....
I've got a power adapter that I use to charge a Li-Ion battery. The power cable end that plugs into the mains is European style on the mains end and cloverleaf on the end that plugs into the adapter. I want to change this power cable so that it has a UK plug on the end.
I've seen many different rated cloverleaf cables - how can I know what type I should use ? What about the fuse ? Do I (should I) first find out what fuse is in the supplied cable ? What about the lead rating ?
Is there a danger of supplying too much to the adapter ? although I guess this is what the adapter is for - to adapt ;o) What about supplying too little ?
