- Joined
- 28 Jan 2007
- Messages
- 39
- Reaction score
- 0
- Country
The radiator in my bathroom is quite small, and i'd like to change it for a double rad. First of all, do rads come in standard sizes? The existing one is 745mm wide and 525mm high. Any similar sized rads i've seen are either 600mm or 800mm wide.
The reason i need it the same size is because the pipes are tiled & grouted around, and it would mean lots of extra work if i was to get a longer rad. The distance between the centre of the flow & return pipes is 810mm, if that makes any difference? Also, would the pipes need to be further away from the wall if i managed to find a double rad that fits? Or does anyone have any suggestions on how to overcome this problem?
Last thing - I've attached a pic of my boiler - can someone tell me how i would go about topping up the system if i change the radiator - i've looked in the wiki etc, but i'm not entirely sure how to go about this.
http://i187.photobucket.com/albums/x228/Dr_Doolittle/DSC00454.jpg
Thanks for you time - i know there's alot of questions there, so even an answer to some of them would be appreciated.
